Homeless_by_Cho
Jun 21, 2015Explorer
smkettner wrote:
Manual page 8 says max 40 Voc so you need those panels in parallel or you are at 44.2 volts. Or a different controller?
MC4 parallel connectors will make this easy. (I assume panels have MC4)
No fuse needed from panel to controller. I would have 40 amp fuse close to battery and at least #6 wire for battery connection.
smkettner,
I will wire panels in parallel and drop the fuse between the panel and the controller. These panels have a terminal strip mounted on the bottom, no MC4 connectors. I will use a 40 amp fuse at the battery and 4 gage wire which I have left over from another project.
Thank you for your comments.
LeRoy
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
