Muddydogs
Jun 21, 2015Explorer
I use a fuse between my panels and controller just to have a off switch. I figured it was easier to wire in a spade fuse holder then mess with a switch. Your install might very but if you disconnect the batteries or need to do some work with the batteries and cables your solar panels will keep things charge unless you cover the panels or unhook them from the controller so I made it easy as all I have to do is pull the spade fuse from the holder which is next to the controller.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
