5outta6's avatar
5outta6
"Plug In" generator transfer switch/relay?
When we purchased our used 2017 Coachman Leprechaun Class C I failed to notice that we have to plug in the power cord into a receptacle every time after starting the generator.
I didn't think of this or notice the sticker stating this at the time of purchase.
My old Jayco class C had the auto transfer switch so I thought they all did..
Anyway, Does anyone know of a 'plug in' relay or transfer switch that I could leave pluged in between the 30amp shore cable and the receptacle for generator power, to eliminate the need to go outside to use the generator?
Any info greatly appreciated
( Last year on on 9K mile trip in the Leprechaun , we didn't need the generator at anytime over 2 months.}
  • Storm coming...
    I switch to batteries before the storm hits. When it's nice and dry. And I suffer more storms than most on this forum. I am wise enough to CHECK generator oil and coolant BEFORE starting it up after a storm.
    Because of GLOW PLUGS, turbo charger, etc. I have a 5-minute run up before I switch on the governor. 550 advanced to 1,200 RPM
    It is common to receive one inch per hour during tropical storms.
    My BiPAP is on a dedicated Group 29 Lifeline AGM separate from the hotel batteries
  • j-d wrote:
    I'd be afraid to use a pair of SPDT relays in place of a single DPDT. I can't draw a diagram to back the thought up, but it seems that if one relay "picked" and the other did not (say a coil failure), we could end up with problems.
    As you deliberate this project, bear in mind there are entry level 30-Amp ATS units starting around $50.
    If the genset is a recent model like ONAN 4KY, it won't supply AC to the ATS (or the coil in a home made one) until its logic board verifies it's good to go. So an ATS with its own power evaluation would be redundant.
    So does this mean you can just leave the house power cord plugged into the generator receptacle and the generator will not provide the power until its 'good to go', eliminating the need for a ATS?
  • I just finished installing a parallax 30amp ( BEST Converter.com) ATS in my motorhome, and let me tell you whomever thought it was good idea to engineer and design where the installation of the PDP and ATS under the bath sink was smoking *ra!k. I have an old wfco PDP(which i refurbished) and the ATS was chattering something fierce. Oh and the climate control "brain" is under there too, water /electric. Hopefully your power is no where near water.
  • DancinCampers wrote:
    If leaving the cord plugged in to generator, just turn main breaker off before starting gen, then after gen comes up to speed turn main breaker on.
    X-2 on above. PLUS like said, that needs to be a DPDT switch or relay.
    Dusty
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
