5outta6's avatar
5outta6
"Plug In" generator transfer switch/relay?
When we purchased our used 2017 Coachman Leprechaun Class C I failed to notice that we have to plug in the power cord into a receptacle every time after starting the generator.
I didn't think of this or notice the sticker stating this at the time of purchase.
My old Jayco class C had the auto transfer switch so I thought they all did..
Anyway, Does anyone know of a 'plug in' relay or transfer switch that I could leave pluged in between the 30amp shore cable and the receptacle for generator power, to eliminate the need to go outside to use the generator?
Any info greatly appreciated
( Last year on on 9K mile trip in the Leprechaun , we didn't need the generator at anytime over 2 months.}
  • It's simplicity itself.
    You just need a small Square D box with wiring knockouts, a 120 Volt coil DPST continuous duty relay, a few wire clamps and wire nuts.
    You wire the Hot and Neutral of the incoming 30 amp cable to the Normally Closed contacts. The Normally Open contacts are wired to the Hot and Neutral of the generator.
    The Common contacts go to the RV. The relay power leads are wired to the Hot and Neutral of the generator, just like the NO contacts.
    So what happens is if you plug into shore power, power goes through the NC contacts and your RV is hot. Now, if you want to run the Generator, just start it up, and when power is available, it automatically closes the Relay, and you have power.
    Takes just a couple hours to install it all and configure and wire it up. Let me know if you need a schematic.
  • You could 'ADD' a standard auto transfer switch.
    That receptacle is the generator power out.....
    You plug our RV Power Cord into it for gen power
    The auto transfer switch...
    Remove that gen outlet and replace with a junction box
    Then wire from junction box to 'GEN-IN' on transfer switch (OR short power cord from Gen Outlet to transfer switch)
    Then OEM Power cord to 'Shore-In' on transfer switch (end that is wired to rv main power panel)
    Then 'Main AC Power OUT' from transfer switch to rv main ac power panel
    OR...just plug ac power cord into Gen Outlet whenever you are unplugged from Shore Power
  • I'm sure you can find an electrician to install it. But, is it worth the $$$? I just leave my cord plugged into the generator receptacle any time I am not hooked to shore power. When I unhook and stow the cable, I just plug it in. If I don't need generator power, the cable is just stowed. But, if I need generator power, I just hit the dash button.
  • You only need to go out and plug it in to the camp ground pole. When you unplug, plug into the generator. When you want to use the generator it will already be plugged in.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
