MrWizard
Jun 09, 2017Moderator
what about other 110v items, TV, MW, coffee maker ?
do they work
your lights are most likely 12v, they and the water pump and vent fans will run on battery, until the battery is too low
when that happens your fridge might shut off, if it uses 12dc power for control
it sounds like the "transfer switch", this is a relay that auto switches between generator and shore power, the contacts are stuck
let us know what rv you have
somebody can tell you where to look for the BOX that is the ATS "automatic transfer switch"
when you find it smack it good with the flat of your hand, that might unstick it
do they work
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
