EagleScout-USA's avatar
May 07, 2015
Plugging into house?
When plugged in at home, should I:
1. plug the trailer 30 amp cord into the adaptor (reducer) then to a standard extension cord which in turn will be plugged into my regular home outlet in the garage, or
2. purchase a 30 amp extension cord (25 feet) and connect that to the 30 amp trailer cord, with the adaptor (reducer)then plugged directly in to my home outlet
I realize not to use any items with a significant electrical draw while not plugged into a 30 amp service, but I want to ensure safety and avoid electrical problems by ensuring I do this right.
Thanks!
  • It will work fine. DO NOT turn your AC on. The fridge should be on as long as the run isnt too long. check the voltage at the fridge to make sure its not too low under load.
    I bought a 50a to 30a adapter because at a lot of the places I have been (military RV parks mostly) the 30a is broken, or tripps at 20 amps etc. The 50a are damn near all brand new.
  • I plug in using a regular extension cord. All I use is the lights and converter to charge the batteries.
    A heavy duty extension cord is a good idea.
  • having an extra power cord may come in handy for some campgrounds so I'd opt for the 30 amp extension.
  • When we first bought our trailer I bought a 50A plug to match the inlet on the trailer. I also bought a heavy duty 25 foot extension cord, cut the end off and installedmy 50A plug. Makes a simple 20/30A extension cord.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
