DrewE
Nov 08, 2015Explorer III
Fridge and water heater use a good bit of power, and you nearly always have a lot more propane energy available than battery power. One pound of propane has energy equivalent to about 500 AH from a 12V battery bank. This means that a single battery is equivalent to maybe a couple ounces of propane.
Note that your microwave uses about as much power as a hair dryer or toaster—it's a power hungry appliance. Your inverter size requirement goes way up when you include the microwave vs. the other things you listed—300W or so would likely be adequate for the other things, maybe a bit more if it's a power hungry computer.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 08, 2026
