SoundGuy
Nov 09, 2015Explorer
JRRNeiklot wrote:
I'm about to buy an inverter for my travel trailer. It has no 12 volt outlets, so I think ac is the easiest way to go.
Why would you expect an inverter which converts 12 vdc to 120 vac to have any 12 vdc output? ... and why would you want it to when your trailer is already wired with 12 vdc? :h Also, without knowing what you intend to use as battery source supply to power this inverter it would be really difficult to say what you could realistically power with this inverter and for how long.
Can I plug the shore power plug (with an adapter) directly into the inverter and power the outlets in the trailer?
Yes, with some consideration. What you're wanting to do is wire the inverter's output to feed the trailer "whole house", just what I did (7 pics) earlier this year ... works fine with some inverters but you sure wouldn't want to do this with any inverter wired with a 60/60 centre bonded neutral output. :E If you don't understand what this means then you'd be best to pass on the idea, keep the inverter's output wiring entirely separate from the trailer's, and simply use your inverter to feed individual devices directly. ;)
Unfortunately you haven't said anything about why you want to do this. :h If it's because you regularly intend to dry camp then I'd say a "whole house" wiring scheme makes sense because you can plug in as part of your setup and leave it that way for the duration of your stay. However, if it's only going to be used intermittently for back up those times campsite shore power may fail then I'd say "whole house" is more trouble than it's worth. A case in point ...
Last month during what should have been a pleasant fall camping weekend on a 30 amp electric site we were hit with a foot of snow, tree limbs falling all around us, and as it turned out power lost to the campground for 36 hrs from 4 am Sat to mid afternoon Sun ...
... and I can tell you it was no fun climbing out of bed in the middle of the night and getting dressed to go outside, trudge through the snow to unplug the trailer's main service cable from the (now dead) campsite post and move it over to the inverter output receptacle. Back inside I also had to turn off the converter, force the fridge to gas, and switch the water heater element off, none of which I initially remembered to do that early in the morning. :M So ... since my use for this inverter is as emergency back up and not because we do any amount of planned dry camping I'll be removing this "whole house" wiring scheme in the spring and instead wiring the inverter's output to three additional duplex receptacles I'll install for the purpose - two on each side of the bed and one near the kitchen galley. To use I won't have to go outside or remember to do anything special at all - just turn the inverter on with the remote control which I have mounted inside the camper and plug whatever device we want to use into any one of those 3 receptacles. Having learned this lesson the hard way I'd suggest that in your case you first need to define just what it is you really expect to use this inverter for, then design your installation based on those requirements ... and that you can't do until you determine just which battery supply you intend to use as source power.
In my case, because my inverter is intended only as back up for those times we may lose shore power, I use my existing G27 battery and with that can power a couple of 120 vac fans, a 550 watt coffee machine, a 650 watt toaster, or even my wife's hairdryer on it's low setting of 350 watts. I could care less about the microwave oven, which is a good thing since there isn't a chance on the planet this 1000 watt inverter nor the single G27 battery feeding it could meet the load. Next year, I might replace the G27 with a pair of G31s which will enable the inverter to handle these loads more easily and for longer periods of time before a recharge is necessary. However, in your case because you're also talking solar, you really should be planning your inverter installation not as a separate project but as one that's part of a integrated battery, solar, and inverter system designed to meet your specific requirements.
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 08, 2026
