ewarnerusa
Nov 09, 2015Nomad
Byrogie wrote:
We are 100% boondocking. Inverter to whole house. "Dumb" converter unhooked.
Fridge and HWH on gas. Battery charging via solar, and if/when necessary, generator and external charger.
^^ +1. Same with us. Plugging the shore power cord into the inverter IS the simplest method, none of this rewiring dedicated outlets or transfer switch stuff is necessary. I suggest taking the microwave out of your plans. Then you can easily get everything else done with the 1000 watt PSW inverter you linked to.
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 08, 2026
