SoundGuy
Dec 04, 2015Explorer
JRRNeiklot wrote:
Now, I really want to use the microwave, so as I see it, I have a couple options. One: leave everything as is, and either do without the microwave or crank the generator if really needed. Two: Upgrade the inverter to this 2000 watt inverter. How much more drain will the bigger inverter be on my batteries?
JMO but powering a microwave oven using battery / inverter source power is about the quickest way I can think of for wasting valuable battery reserve that could otherwise be used so much more effectively for other purposes. I personally could care less about running the microwave oven when dry camping but if I did I'd simply power the entire trailer with our 2K genset.
As for inverter draw my own 1000 watt true sine wave inverter pulls 350 ma at idle, probably typical for this size, so it wouldn't surprise me if a 2000 watt version pulled twice that.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
