BFL13
Dec 04, 2015Explorer II
JRRNeiklot wrote:
I've done a lot of work on the camper, so I thought I'd update this thread. I have installed two 250 watt Renogy panels, charging 6 205 AH batteries for a 12 volt battery bank of 615 amp hours. I'm using this Microsolar inverter. It works fine, but will not run the 900 watt microwave. I put a killowatt meter on the microwave, and later on the shore power plug itself. The microwave is drawing about 1325 watts and the shore power plug pulls about 1370 with nothing but the microwave and various power lights for things like the propane leak sensor, dvd player, etc (not the appliances themselves).
Now, I really want to use the microwave, so as I see it, I have a couple options. One: leave everything as is, and either do without the microwave or crank the generator if really needed. Two: Upgrade the inverter to this 2000 watt inverter. How much more drain will the bigger inverter be on my batteries?
As always, thanks for any advice.
You do need a 2000w inverter to run the MW. That looks like a good price for a PSW one. I would try it out since it could be a "re-brand" of one of the main brands and so just as good (or bad). As long as there is a return policy if it fails and it wasn't your fault like a reverse polarity would be.
You could be camping where you want to use the MW before or after "generator hours" or "quiet hours" and that is when you want the inverter for sure. You can recharge the batts later during generator hours.
MW doesn't take much out of a battery bank because it only runs for a short time. 10 minutes at 140 amps is only 23 AH which is peanuts on a 615 AH bank.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
