JRRNeiklot
Dec 04, 2015Explorer
SoundGuy wrote:
With a claimed 615 ah battery bank supplying power draw by the inverter itself, regardless of size, should hardly be a concern especially considering you seem determined to expend so much of that reserve so quickly by powering a microwave oven. Doesn't make a whole lot of sense to me but it's your rig so obviously you can run it anyway you want. :R
Well, obviously, I'm not going to use 615 ah. I'm going to try and keep it to a maximum of 300, though I really don't think I'll come anywhere near that. And the microwave will draw less than 30 amps over 10 minutes, as BFL13 says above. I doubt I'll use it more than about 3 minutes a day if that.
I'm honestly not going to be running that much, I just wanted to be able to if the need arose,hence the large battery bank. I'll generally run the tv, maybe the fridge on occasion to save propane, a laptop, run a fan or two, and charge some usb stuff.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
