SoundGuy
Dec 04, 2015Explorer
ewarnerusa wrote:
I'm all for having excess capacity ...
There's "excess" and there's EXCESS, which is clearly what the OP has needlessly gotten himself into for the sole reason he wanted to include powering a microwave oven which is a hugely high draw appliance in that list of otherwise small draw items he has. :S RJsfishin is right on the money with his observation - "Your problem is that you really don't know how much battery power it takes to run 120v stuff that is really made to run on shore power. Then having said that, you don't have any idea how much charging power you will have to produce to replace all the power that you are going to consume if you power what you think you want to.
And to the OP, I never said you would draw 615 amps, merely that with that large amount of battery reserve any idle draw imposed by whatever inverter you choose will be insignificant in the overall scheme of things, regardless of how much or how little the inverter is drawing from that battery bank at any given time. You've got a gas absorption fridge but are running it on 120 vac shore power supplied by an inverter that in turn is supplied by a huge bank of SIX 12 volt batteries that in turn is relying on solar for recharging?! Why? :h Your fridge was designed to run on gas, use your battery reserve to power the fridge's electronics, just as it was intended to be used. Conserve your battery power for those items that absolutely require it and you wouldn't need anywhere near this amount of EXCESS battery reserve.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
