westend
Mar 24, 2017Explorer
The name of that connector is 1/2" (appears to be from image posted) female flanged connector with hose bib. You can purchase a "T" with two hose bibs and a threaded connector for the bidet supply line. In that case, you would cut the braided hose to install the 'T". A conventional steel braided supply line should connect to the fitting and have as much sealing as your original plastic connector, even though the center sealing gasket "protrudes" more than the original.
If the supply valve has stripped threads (and it looks like the braided hose has an injury), it may be better to remove the hose and start with conventional fittings, a new valve, and a steel braided supply line from the wall. Installing a full-flow ball shut off valve while you're at it isn't a bad idea, either. If the toilet or bidet develops a leak when you're traveling, the shut off valve allows use of the rest of the fresh water system until repair is completed. I have shut off valves and steel braided supply lines on all my fresh water fixtures.
Good luck with the plumbing!
BTW, don't reef on the steel connector to cover all the threads on the valve like your plastic connector. It's not necessary to thread it on to cover all the threads on the valve. I believe this is your original problem.
