Bierp
Sep 27, 2017Explorer
Ok, we've taken a few trips now and I wanted to follow up on this. I know that someday someone like me will find this post and hopefully I can save that person some pain. :)
The setup above worked wonderfully as far as plumbing was concerned, but I did have to make one more adjustment. I ended up replacing the toilet seat with a 'home' style seat that was specifically flat on the bottom. This allowed me to adjust the bidet far enough forward to give the extendable 'pressure washer' room to fully extend.
This was the final piece and once I did that everything was wonderful!
Having a normal seat is also a lot more comfortable than the default plastic seats. It's maybe 1-2 pounds heavier, but in my case weight isn't really a factor. It's also in front of my axles, which is good.
For those of you still using paper to smudge things around, consider the bidet. It's cleaner and more hygienic and in the RV it means both using less of that flimsy camping TP and having less TP in your black tank. That's a win/win in my book.
It does use more water, so maybe not as good for dry camping, but for those like me who consider roughing it to be bad wifi, this is the only way to go. :B
Thanks again for all the help I got from everyone.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
