wa8yxm
Dec 26, 2019Explorer III
There is often an outlet strainer on the tank and an inlet one on the pump. FOLLOW The lines to see if they are on the inlet side or outlet.
Accumulator tank will be on outlet side.
Also there is a fresh water strainer (usually the screen washer at the inlet) and there may be a fresh water filter as well (much larger holds a couple quarts of water in it's housing if no filter present)
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
