32vld's avatar
32vld
Plumbing Material I Shoud Use
Original post :
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28155531/gotomsg/28199286.cfm#28199286
It turns out the truck is a 1946.
He install the sinks and now needs to hook up the sinks, water pump, water heater, water tanks.
Can we use PVC pipes, white RV/garden hose?
  • I would use 1/2 PEX. Red for hot blue for cold.
    other post you could use the same Pes for the vent line. it should have a small screw to keep bugs and debris. Should find in your local hardware store.
  • Yup pex and PVC is the way to go..buy a cheap crimping tool or use press sharkbites or equal...LI yea
  • I suggest using PEX for water supply lines; PVC for drains.
