Has anyone replaced the fresh water drain plugs with valves? Same on FW tank drain line. We camp almost year round and often winterize several times a year.Can I get the parts at a big box home depo...
Simplest way is to unscrew what you have in the tank. Take it to the hardware store and figure out what they have to replace it with. I replaced the ball valve with a pencil sized hole they had in mine with a 1/2 inch fitting in the tank and a 1/2 inch ball valve.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
