I_am_Yu's avatar
I_am_Yu
Plumbing pressure relief
I'm running on internal water (not city water). I don't leave the water heater turned on all the time (too wasteful to do so) and when I turn it on it raises the pressure in the whole plumbing system way too high, and I get water leaking from the toilet onto the bathroom floor. The only way I've found to deal with this is to shut off the pump and briefly open a faucet every 10 minutes to relieve the pressure, until the heater gets hot and the pressure stabilizes, which gets pretty annoying.
There is a pressure relief valve on the water heater, but apparently it's only intended to protect the heater tank, and opens at too high a pressure to do anything for the plastic plumbing.
Is there some kind of relief valve that opens at a lower pressure, which I could install somewhere in the system and have it drain overboard?
  • A small accumulator will solve the issue. Yes I had the same problem.
    Amazon - Shurflo 181-201 Accumulator Tank $38
    This creates a permanent air pocket.
    Mine was in the RV shop twice for several weeks for a mystery water leak. Never found. I had to dig for this myself while camping. I guess the dealer did not think to cycle the water heater to find a leak.
  • Lynnmor wrote:
    Drain the water heater and refill it, that will re-establish the air pocket in the tank and allow for expansion. See your water heater owners manual for more information.
    Or just turn off the pump and drain a small amount out. Then turn the pump back on without using 6-10 gallons of water.
  • Drain the water heater and refill it, that will re-establish the air pocket in the tank and allow for expansion. See your water heater owners manual for more information.
  • I like installing a small bladder type pressure tank. It makes the whole water system work nicer.
  • Sounds like a faulty check valve on the cold water line at the water heater.
  • Intresting problum, maybe try to turn down the tempature of the water heater. Less heat , less expansion , less pressure, maybe.....just an idea.
  • I have the same issue. I turn off the pump and leave a HW tap open. When the tap starts to drip I turn off the heater.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
