Old-Biscuit
May 31, 2015Explorer III
WH Tank gets scaled up from heating water...especially if water source is hard then that scale can be carried thru the hot water lines.usually plugging up faucets vs lines
Have you disconnected a hot water line at either faucet.........then run pump and blow line out into a bucket?
(This will help check if problem is in hot plumbing lines or in hot side of faucets)
Vinegar soak............takes more then 2 gallons
Need to do a vinegar soak of WH tank and then hot plumbing lines'
6 gallon WH tank........4 gallons of vinegar/2 gallons water
Have to pour vinegar into WH tank by removing T&P Relief vlave and use a funnel. Then reinstall T&P
Turn on water supply and fill WH Tank.
Then turn on WH..........let it heat the vinegar/water solution up 4 cycles (without using any hot water)
Then after last heat cycle....run hot vinegar/water solution thru HOT water lines.........let it soak for couple hours.
Then drain/flush/rinse system
