Bobbo
Jun 01, 2015Explorer III
Old-Biscuit wrote:Puttin wrote:
If everything that Bisquit says doesn't do it and it turns out to be the check valve at the bottom of the water heater you can just take a fine stiff wire and pry the guts out of it (after you've taken the output line off of it). In that case, I hope yours is easier to access than mine was. Sometimes they make a humming noise also when you turn any hot faucet on.
Depending on who installed check valve (if used) ....could be in hot outlet vs cold inlet
The check valve will always be on the hot outlet at the top of the water heater. If it is on the cold inlet, it will still let the water heater back fill with the pink antifreeze, at least until it pressurizes to stop further flow.
