Almot
Nov 28, 2018Explorer III
"Ass-uming" 12V panels...
#1: It depends on your criteria of "good" and your budget. Off the top of my head, EP 30 will do, subject to input volts limit (BFL probably remembers that number). Morningstar Tristar 45 will be nice, for much more money.
#2: Controllers normally have ONE input for panels, i.e. Pos and Neg. Any combining of panel wires is normally done on the roof waay before the controller. In case of series it's just plugging panels pigtails one into another.
#3: Normally, panel pigtails are #12 or #10. Plenty thick for series, not enough for parallel 3*150W.
#4: Did you mean "MC4 extension cables"? Yes. Panel pigtails - not really, because they are normally soldered to the panels. Yes, there are #8 extension cables with the same MC4 connectors (again, "assuming" you have MC4 since you didn't tell this). No, #8 is not necessary for series 3*150W, but for parallel you might need to combine pigtails into #8 or #6 before routing into the trailer.
#5: Will hardly affect in series. In parallel you might need combiner box and #6-#8 cable.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 30, 2026
