Almot
Nov 29, 2018Explorer III
Details, please.
12V panels, alright.
Are they MC4 connectors? If so, you can use MC4 Y-splitters to wire 3 panels in parallel.
As noted, wire gauge to controller (especially in parallel) is distance-dependent. May or may not need to go #8 in parallel. At some point you might lose too much voltage in existing thin cable - assumption here again, likely you have #10 cable - and controller won't get enough for Absorb stage. It WON'T hurt to go #8 in parallel, and with MC4 (assuming again that your panels are MC4) this is easily done.
In series you don't need #8, but to wire panels in series you need MPPT.
28A into 30A PWM controller would be cutting a little close. OTH, 30A MPPT will easily take 30-35A.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 30, 2026
