LarryJM
Jun 16, 2013Explorer II
BobsYourUncle wrote:
Thanks for your input everyone.
This cabinet is going to be removed, scrapped and replaced with a matching wood one. The cabinet is simply not suitable for RV use.
If I can find a wood one somewhere I can buy strips of oak or whatever and fasten them along the bottom to make a barricade to prevent stuff from falling out.
I am one of those people who will get rid of an offending item and replace it with something functional. I have never been one to Mickey Mouse something just to get by with it. Hooks and rubber bands isn't going to happen, but I appreciate the suggestion! I have always been that way!:)
As you just admitted even a higher quality cabinet you still will have to have the same modifications to prevent things from falling out as the one you say is not suitable for RV use.
I also looked closer at your pic and that bottom shelf with the stuff stacked haphazardly with bottles on top of bottles will need more attention than just a different cabinet or a simple lip which BTW won't keep taller items from leaning against the door and then falling out when the door is opened.
Quite a few others have given you the actual solutions they have successfully used and I bet you will end up using something similar even with your replacement cabinet to really solve the issues you mentioned.
Larry
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
