Mickeyfan0805's avatar
Nov 16, 2017
Poor pump pressure
Our water pump seems to be giving us almost no pressure. I can get it to pour very lightly out of the faucets and dribble through the toilets, but it doesn't even have enough pressure to send water through the shower, much less actually use it.
With the rig now winterized, I won't get to it until spring, but is is safe to assume that the pump is dying and needs to be replaced, or are there other issues that should be looked at before I replace it?
  • I would consider the pump screen is blocked. But it also depends on how old the pump is and how much you use it.
  • you may also have a filter on the input side of the pump and it may be clogged.
  • Without any leaks, yes, pump is dying, or voltage to pump is low.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
