ice2fire's avatar
ice2fire
Poor water pressure at shower head
According to the gauge I have just after the outside tap, the campground's supply water pressure is about 42 lbs. However, in the bathroom, at the shower head, it's about 50:50 dribble:jets of water. I've checked the hose pipe, and the inlet on the side of the trailer, and the shower head itself for clogging, but every thing seems to be OK. The water coming out of the bathroom sink taps seems to be fast enough, however, the outside connection is just right next to the bathroom sink, about 2/3 towards the back of the 30' trailer. But water coming out of the kitchen taps is slow, even with the "water saver" part in the head removed. The kitchen and the hot water tank are right at the front of the trailer.
It seems a clogging issue, but I'm not sure what next to investigate.
No outside water filter is connected. I took it out of the hose pipe supplying water hoping that was the problem. The water here in Tucson has a high mineral content.
Any suggestions as to what I could investigate ?
  • When changing out my shower valves, I found a built in water flow limiter.
    I don't remember how small the opening was...1/4" or less, maybe.
    No ideas on kitchen sink.
    Pat
  • boy that is amazing. you just described my water issues in my TT too. if you find out what is going on, let me know Please. thanks
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
