1L243
Jul 05, 2022Explorer II
bgum wrote:
Please describe what you are doing with the condensation. I have a portable but it is rarely used and have never hooked anything to the AC other than the large hose. It does have a small 1/2 inch fitting with a cap on the end.
I'm using clear tubing on the fitting with the cap on it. Remove the cap and mine also has a plug inside the tube and screw on the clear tubing. I am running about 5 feet of tubing out the same vent as the AC exhaust.
I'm using larger clear tubing to go over the 1/2 inch fitting. It's a tight fit it kind of screws on. I use smaller clear tubing that fits tightly inside that tubing so I don't have to use such large tubing to where it exits the trailer through the side vent.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
