rockhillmanor
Oct 14, 2018Explorer II
My first battery operated fans where o2cools too.
I needed to keep the dogs cool and safe driving thru the south in summer time.
Unless you have stock in the energizer bunny you will "literally spend $100's of dollars on the batteries" for those fans and they last all of about 15 minutes. And if you use them a lot like I did they just up and die.
I threw them all out in the dumpster at a CG!
Here is what I bought to replace them.
These fans are big, "powerful", low and high speed, RECHARGEABLE batteries AND each charge lasts a loong time. I bought an additional battery kept charged so I can keep these fans running forever.
Ryobi
(this pix is from back when I bought them. I think they have redesigned the look of them since then)
Fan Stands flat or you can hang them up by hook attached to back.
http://www.homedepot.com/p/Ryobi-ONE-18-Volt-Hybrid-Portable-Fan-Tool-Only-P3320/205022215
Can't say enough about this portable fan.
Ryobi
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
