JusBud's avatar
JusBud
Portable flux wire welder recommendation
We do a lot of boondocking and off roading so I carry an 80 amp wire flux welder.
It's too small even for around the house.
Not sure if a 130A will be much better especially on 115volt but it won't break the bank.
130A
I like this one since it's dual voltage. I do have a 220volt outlet at home.
You can also use sticks and I've welded with those too.
I probably won't get gas bottles and gauges but at least it has the option.
165A
  • so 2many, is that Lincoln a DC?
    You sure posted some nifty looking welds with it.
  • The real cheap welders from Harbor Freight and others, are usually AC output. You should buy only a DC MIG welder if you want anything that resembles a good weld. Finding a DC that runs on 120 volts might be harder.
  • I bought a Lincoln 100A model years ago. I later bought the optional kit to make it a true MIG welder. Absolutely fantastic for all my home projects. I have the larger 140A version at work. Even nicer, but bulkier.
    Here's my 100A:
    Once you use a MIG welder, you won't bother with flux core again. Virtually no clean up, welds are ready to paint.
    Here's the small pony bottle I take when using this in the field:
  • Tom_M wrote:
    Read the fine print. Coupon not good for welders. Their cheapest wirefeed is $114.99. It routinely goes on sale though for about $90.
    The 20% coupons are nice but, they're like an extended warranty. They have a lot of exclusions.
  • I bought one from northern tool. It's a little more, but much better than the one at harbor freight I think anyway, read the reviews before you buy.i did try to run mine off a h/f 4000 Genny, wouldn't do it.
    Really like the h/f gennys, I don't think they are very loud. Of course I only use it for the house.
  • JusBud wrote:
    I was just printing out their 20% coupon.
  • Funny you mention that.
    Going over there later today
    Thanks
