Gdetrailer
Feb 20, 2022Explorer III
BFL13 wrote:
Still not clear on the choke aspect. Assuming you leave it on and the battery does not run down meanwhile, you can use the fob to start it wirelessly.
However, recoil starts with the gens I am used to have a choke with a lever you slide over once it warms up a bit after getting going.
How is this achieved with wireless remote start gens like the Chanp 3500 linked in the OP?
Thanks.
I believe the choke is connected to a solenoid, when cranking the solenoid closes the choke. Let up on the remote button when the engine catches and the solenoid relaxes and opens the choke..
Of course, there is the possibility of a spring loaded "automatic" choke like you used to see on many small lawnmower engines.. Spring is strong enough to lightly close and hold the choke when cranking but not strong enough to hold choke closed when engine is at speed..
Generally only need choke during startup when cold so most automobile "automatic" chokes used a simple bimetalic spring which when cold it shut the choke and as it warmed up, it relaxed and opened the choke..
