Feb 21, 2022Explorer II
routeforty wrote:I replaced mine with a YTX7A-BS AGM motorcycle battery that lives on a 13.3V float charger.
I assume you replaced the original battery. With what? Did you go with the same size or a larger one? Gary
I have not let it sit overnight with the switch on after the 1st failure. I might try it again at the house when I'm not relying on it.
Side Discussion: I wasn't sure what voltage to float this battery so I charged it at 14.6V until the current no longer dropped for an hour. Then I let it set for 2 days and it measured 13.3V. Let me know if there is a better way.
