kerrlakeRoo wrote:
Champions, Predators and most other cheaper brands use Chinese engines which are clones of Honda designs. Most internal parts are readily available.
They generally seem to give good service, not to the same degree as the original, but at 1/2 to 1/3 the cost they are economical choices.
As to noise, the difference from 57 to 58 Db is not within my range to differentiate.
Then again I always thought it funny to hear someone that spends a lot of time riding a harley complain about the noise from a dirtbike.
No matter the brand, to someone, they are all noisy.
If you are looking at it for charging the batteries only though, why that large when a 2000 will do the job and be much easier to store and handle?
Just for sake of argument, 1 Db is a lot, if you are right at your point of tolerance. Also, newer Harleys did not come from the factory, loud/noisy, the owner made/had it made that way. All dirt bikes, even off road only dirt bikes may not be noisy. Mine is not noisy, but just kind of loud.:)
Oh, to answer OP, I would choose one of the many Champion quiet generators, due the the reputation, price, and Champion support.
Jerry
