MrWizard
Jan 08, 2014Moderator
yes you can plug it in
BUT depending on how big the internal charge circuit is and how it is wired
it might not supply enough power for continuous use
in other words it will slow down the internal battery discharge, but I would be surprised if it would supply a full nights worth of TV, especially with many devices running from the inverter and using the battery power
I suggest you try it, and see if it provides satisfactory results
