TomG2
Jan 11, 2018Explorer
To the OP: You will need at least 1,000 watts to keep your laptop charged and run a couple of lights. That is about what you are going to hear. I have done exactly what you want to do with a single 100 watt portable panel, by the way.
The RV lights and water pump are almost certainly 12 volt and will be powered by your RV battery. I like to keep things simple. Therefore, I connect the output from my panel controller directly to the RV battery with battery clips. Charging things like a laptop can be done with a small inverter or better yet, a 12 volt adapter.
Solar can be as simple as my setup or as complicated, and expensive, as you want to make it.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
