ohhell10339's avatar
ohhell10339
Portable solar for limited current draw
I want to be able to generate enough power to run my laptop and keep a couple of lights inside the RV lit.
1. Will a 100 watt portable solar array do it? Or will I need 200? (Let's assume that I'll usually have sunlight.)
2. What's the easiest way to use the DC output of the panel(s) to light the interior of the rig (and maybe run things like a fan and/or the water pump)? In a rig that doesn't have a generator, where would the interface be? (I assume it would be horribly inefficient to run the output through an inverter and then connect the inverter to the shore power plug.)
3. Likewise, what would be the mechanism I would use to charge the house batteries with the panels' output? Keeping in mind I want all this to be portable, so no permanent hard wiring.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
