Roadpilot
May 12, 2017Explorer
I had a 220 vac 7KW tankless that a plumber installed. It didn't work (southwest florida!) so I measured temp. rise. It was right on spec at 30 degrees F. I put in a 15 KW and it works great in SWFL.
The spec on any tankless is temp rise for a given flow rate. Slow down the flow and temp rise increases.
Thinking outside the box I wonder if you could put a submersible water pump in the tub and pump from a full tub into the tankless until the temp rerached your goal. The water gains a few degrees rise with every trip from the tub to the tankless to the tub.
