- dclark1946ExplorerWe use the Coleman Hot Water On Demand portable system which I think is still available. It uses the one pound propane tanks and a rechargeable battery to power a water pump and the burner igniter. The pump attaches to a Coleman 5 gallon water bag but you can also buy an accessory that attaches to a water hose. The burner ignites when you turn on the water. Our kids used this in the National Park for showering (using shower attachment that attaches to the faucet)and it worked fine.
- mobeewanExplorerThe Eccotemp L5, L7 & L10 are all very portable outdoor units using 20 lb propane cylinder or smaller. It requires 2 - D cells for the automatic electronic spark ignition.
- DrewEExplorer III
drsteve wrote:
Lantley wrote:
d needs power.
Mine has a standing pilot, with a mechanical spark ignitor to use if it happens to go out. But yeah, power is required for units that have automatic ignition.
I have a rather vague recollection of seeing some available that used some sort of a little turbine thingy in the water to generate power for ignition, perhaps in combination with a battery or supercapacitor or other device to store the charge. - drsteveExplorer
Lantley wrote:
drsteve wrote:
Wild Card wrote:
You can take a Renii or Bosch tankless and make it portable. All they need is gas, water flow and 110v to run
The tankless Bosch in my house doesn't need electricity. I don't believe any of the propane powered units do.
The best setup I ever saw was years ago while at a rustic campground frequented by dirt bikers. Guy had a portable shower stall like you'd see at a hazmat cleanup site, with a residential propane tankless and a gas powered water pump. Throw the supply hose in the lake, fire it up, and take a nice hot shower, with loads of pressure. Waste water went to a blue tote and got dumped into the campground's vault toilet.
Unless there is a pilot light it has electronic ignition and needs power.
Mine has a standing pilot, with a mechanical spark ignitor to use if it happens to go out. But yeah, power is required for units that have automatic ignition. - LantleyNomad
Unless there is a pilot light it has electronic ignition and needs power. - drsteveExplorer
The best setup I ever saw was years ago while at a rustic campground frequented by dirt bikers. Guy had a portable shower stall like you'd see at a hazmat cleanup site, with a residential propane tankless and a gas powered water pump. Throw the supply hose in the lake, fire it up, and take a nice hot shower, with loads of pressure. Waste water went to a blue tote and got dumped into the campground's vault toilet. - westendExplorerPut a black barrel or bladder in the air, high enough for gravity flow. Put it in the sun and report back the water temperatures. I guarantee it will be too hot, in most cases, if left to achieve maximum temp. The differential then becomes time left in the sun rather than temp rise/flow of a gas unit.
MrWizard wrote:
Most 'portable' tankless heaters are propane, and can turn COLD creek water into hot shower water
Portable camping water heaters are NOT electric
i don't see why what the OP asked will not work
use a barbecue LP tank the portable heater connected to the outside water tap
and fill his tub/sauna/whatever for a hot soak on the patio
The LP models state a 30 to 35 degree temp raise from inlet water temp. So, COLD creek water(lets be generous at 60 degrees) would be 90 to 95 degrees output. THAT is NOT hot water. Now, they are designed for quick showers at Campsites. NOT designed to fill mini-bathtub to soak in. Once you start attempting to fill a Bathtub the water will quickly cool down(not much) but enough to nullify the type temps you want to soak in. Now the Larger L10 model may be large enough to do the job but it is not as portable as the L5. Doug- Wild_CardExplorerYou can take a Renii or Bosch tankless and make it portable. All they need is gas, water flow and 110v to run
- MrWizardModeratorMost 'portable' tankless heaters are propane, and can turn COLD creek water into hot shower water
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 22, 2026
