shane102
Oct 06, 2015Explorer
The monitor is a kib.
14.36 volts is measured at the converter output side of the fuse panel where battery cables hook up.
When hooked to shore power and batteries disconnected and nothing on the output volts of converter are 14.36 volts. If I turn on lights the volts drop to 5.73 volts and lights are very dim.
Converter is a WFCO.
Thanks for the replies. I am guessing that the converter is bad because the voltage dropped from 14.36 with no load to 5.73 with a load??????
If so what is a good replacement converter. And I would prefer to spend the money and end up with a good reliable fix.
