MrWizard
Jan 30, 2017Moderator
That explains what happen
The 220 most likely shorted out the transfer switch
The tripped breakers are actually a good sign
The in rush current tripped them
There may not be as much damage as we suspect
The most expensive item will be the built in generator
Test everything thoroughly
You might want to call an RV tech and have him check things out for you
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
