for the converter,
whats the difference between battery and light bulbs, there is a current drain
i will agreed it should have timed out and drop the voltage
MNtundraRet wrote:
The converter/charger should only output around 13.2 volts if battery(s) are charged, or on disconnect. A working charger would go to around 14.4 volts if it sensed a draw from week batteries.
I suspect that the converter/charger is faulty, but with the battery(s) on "disconnect" the converter/charger may have been fooled by a erratic short form a bad light fixture to sense battery(s) needed charging.
I would have expected with the voltage output seen that the charging unit would have aborted charging, or a fuse blowing. The converter/charger has poor voltage regulation, and possibly the converter was fused on the wrong side of the circuit.
