SidecarFlip
Nov 24, 2017Explorer III
gbopp wrote:
How did the Firman work after you repaired the fuel valve issue?
I see there is no reply to your posting. If it was me, I would have removed the fuel petcock, took it apart, retapped the hole and replaced the screw. The petcock seals with an 'o' ring and the stamped metal outer cover provides the sealing force as well as the turning resistance. Easy fix actually. And if the unit runs well, why not repair it and continue on instead of returning it and then bashing it.
Just like and mechanical thing (your vehicle included), things fail or were assembled incorrectly and fail. I don't see it as a terminal issue, just a quick fix.
Just me I guess.
