Almot's avatar
Almot
Explorer III
Dec 08, 2013
Powdery paint on EPDM roof
Trying to clean the EPDM coat for installing solar panel mounts, with roof sealant under the mounts. With tapping screws into the roof plywood and rafters.
The white "paint" doesn't look like a paint at all. Rub it with a wet rug - the rug turns white.
Rub it with Methanol aka Methyl alcohol - same story.
Put on a Scotch tape for the night, to cover the drilled out pilot holes for tapping screws for the night - the tape picks up the whitish stuff. Repeat it again with tape - same story.
To get a good adhesion with a sealant, the EPDM should be clean. Whitish stuff coming off means that the sealant might come off with it.
Should I hit it with Acetone, or what?
The trailer is relatively new, 2 years, and the dealer might have put some wax or other cr-ap on it, to make it look nicer, but after washing with water and alcohol it's still there. And it's "powdery", not "waxy". Comes off on wet fingers. I'm trying not to walk much on it, and mostly crawl on all four, and my black jeans are white on the knees after crawling around, even on a dry surface.
Is this normal, any ideas?
  • Are you positive it is a EPDM roof? Some of the trailers use a PVC type roof. I would call the OEM (Dutchman) and ask them which they installed. The PVC type you MUST use the same primer that you use on regular PVC pipe to get anything to adhere to the roof. Doug
  • Almot wrote:
    BFL13 wrote:
    Somebody posted that white powder comes off for ten years and then all that is left is a black roof.
    Makes sense, if this is oxidizing, i.e. slow disappearance of the white coat. The "white EPDM" is actually black on one side, so the white surface is a paint. When all the paint is gone, you see the real black color. Thorough cleaning on that small area for the bracket brought up some black dots where the white paint has worn thin.
    You got it, it is a coating that is oxidizing and separating from the underlying EPDM.
  • Almot's avatar
    Almot
    Explorer III
  • Somebody posted that white powder comes off for ten years and then all that is left is a black roof. Ours is ten years old and still white, but we do get the "powder." Gets on your knees if you are working on something while on your knees.
  • Scrub it with either Spic 'n Span powder or 20 Mule Team Borax. The purpose made products like Protect All cleaner really do a great job though.That is most likely the roof oxidizing- normal, but a pain :)
  • Almot's avatar
    Almot
    Explorer III
    Ok, will try next time. Meanwhile, diligent rubbing with water and alcohol has helped. The sticky tape test revealed no whitish stuff coming off anymore. The surface is smooth to touch and shiny.
  • White coming off a RV roof is normal. We use lacquer thinner to prep for applying Eternabond.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
