BFL13 wrote:
Well, here are the calculations I ran over the weekend. Maybe someone here could verify them for me? Thanks.
Now, the real question - I have decided to replace my WFCO 55A converter with the PD 35A converter with built-in charge wizard.
The physical dimensions on the PD for all versions are the same, and PD's 55A version is a suitable replacement for my WFCO. Since the PD dimensions on both 35A and 55A are the same, I make the leap that the 35A will fit in my opening?
Will the PI 35A version do its job in my trailer (and with my Honda 1000), even though it is replacing a 55A converter? Would there be any benefit to me to get the PD 45A version?
Wiring will all be sufficient, right?
I changed out the cheap converter on my first Fun Finder (it was not a WFCO) with the PD, all by myself, with help from you all here. I lived to tell the tale, and I thank you.
