xzyHollyxyz's avatar
xzyHollyxyz
Power Center/Converter 101
I prefer to boondock - A LOT. I have a 2015 Fun Finder 189FDS (it's 30A). I have a Honda eu1000i generator.
Current trailer has a WFCO 8955PEC Power Center (I have no idea what the PEC means because I'm looking for the physical dimensions and can't find the PEC version.)
From what I have read in the past, this WFCO is not a very "good" converter; I do not know what "good" means - is "not efficient" a correct description? It does its job, I guess, but maybe something else would put the generator to better/more efficient use while boondocking?
Questions:
1) What, if any, would be the benefit(s) of changing the WFCO for a Progressive Dynamics converter?
2) Could my little trailer use a 35A PD converter, instead of the current 55A? I don't understand why it's a 55A converter in a 30A trailer. I'm guessing it's because CruiserRV buys them in bulk.
3) Would a 35A converter charge the battery "better/more efficiently" using the generator than does the 55A WFCO?
4) Do you think a PD would fit in current opening without major overhaul?
5) IF I made the change to a smaller amp converter, would the wires be appropriate?
I don't know if I've used all the proper terminology in this post, but maybe try to keep your replies simple, yet informative, for this electric/electronic new person...pretend you are talking to an inquisitive child. ;)
(Why, because of you all here, I learned earlier today how to disconnect the .5A hour heating thing in the seals on my new Dometic fridge! Think of all the people you guys help with patiently sharing your experience and knowledge).
There - was that a proper sucking-up? :)
  • 2oldman wrote:
    This is sort of RV electric 101 which I highly recommend for electrical newbies:
    12v side of life.
    I've read it a couple of times in the past. I believe it was actually bookmarked on my last laptop.
    But these are more specific questions than he answers.
Having RV issues? Connect with others who have been in your shoes.24,196 PostsLatest Activity: Feb 08, 2025
