qtla9111
Jun 02, 2013Nomad
Power Center/Converter
I have a wfcoelectronics 8900 series power center. With too much time on my hands until we leave in two weeks, I have been playing with the inverter. I have it attached directly to the batteries and want to plug the rv directly into the inverter. Our usage is only a couple of LED table lamps, occasional television and laptop use.
I know I need to disconnect the converter, or remove the main fuse (not a technical person). Is that the same as turning off the "main" breaker?
I ask that as I have the rv plugged in here at home and when I turn off the "main breaker" it appears the converter stops running.
Is this what I want to do to be able to connect the rv directly to the inverter to have access to my 110 outlets?
Thanks in advance.
Thanks in advance.
