2000flair's avatar
2000flair
Power converter fried
The power converter on my 2000 flair (inteli power 9100 45A) started tripping the breaker and ended up dying (when i test with a multimeter it shows shorting).
I checked all the wires going to the breaker panel and nothing seems problematic. I removed the unit and connected the rig to the shore power and it looks lime everything is working normally.
I am looking for a replacement so i have several questions:
1. Can i still use the RV without it while the replacement part arrives?
2. Do i have to use the same model or can i order a different one?
3. Is there anything else i should be checking to make sure the new one is not damaged when i install it?
Any pointers will be much appreciated.
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 09, 2026
