time2roll
Jan 30, 2015Nomad
You need a new extension cord with #12 wire minimum.
Any chance it was an old cord with a weak connector?
Get it plugged back in and measure the DC voltage in the fuse panel. s/b 13.6 volts. Disconnect the negative battery cable for this test. Basically the converter is 120vac in, 13.6 vdc out or it is shot. Turn on the lights to load it up a bit. If it needs replacement there are much better converters for just a few dollars more.
If you have a portable charger go ahead and charge the battery and see how that goes. Battery might be shot and caused a heavy load on the converter and cord. Maybe just take it down to be tested.
Post what you find.
Post what you find.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
