Hslag's avatar
Hslag
Power convertor install ???
Ok my convertor is bad I purchased awfco ultra 3 9800 series convertor charger went to put it in and I have no 110 plug in to plug it into I have a black and white wire that was feeding power to the old unit how do I wire this up ??
    Hire someone to install it correctly including the ground wire.
  • The easiest and probably best solution is to install an outlet to plug the converter into.
    It may be possible to safely splice the wires you have together (cutting off the plug on the converter) as well, depending on the exact setup. It may also be impractical to do that safely and properly.
    If you're not sure of the wiring, I would strongly urge you to hire or get help from a qualified person. It's not particularly complicated or difficult, but not doing it properly can create a significant shock and/or fire hazard.
  • install an outlet in your cabinet? or remove the appliance cord, and hard wire it in?
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
