salem's avatar
salem
Power Cord Connection
I bought a new electric razor today. Directions said for best results charge the battery for 24 hours. It also said to plug the power cord into the razor first, and then plug it into the wall socket. I remember reading on this forum some time ago that you always want to plug your trailer power cord into the trailer first, or into the adapter, whatever, before plugging it into the electrical outlet. It was an interesting post, but now I cannot recall the reasons for this. Anyone care to enlighten us? I believe it had to do with the electricity surging into your trailer, but I don't recall how plugging into the trailer first stops this.
  • If you plug the trailer cord into the trailer first, your more likely to make sure the breaker at the site power stanchion is off before plugging in that end. Plugging either end in with the power on is not recommended due to the likely contact arcing.
    Regarding the razor, I suspect the intent is that the contact area at the line plug is much larger than at the razor end, and better able to handle any potential arcing if the razor happens to be switched on when plugged in.
