Almot
Oct 25, 2014Explorer III
If you get a TV, go for at least 1080p resolution. Most popular computer monitor resolution now is 1366x768. 1080p TV meets and exceeds this requirement. 720p TV is a bit below this plank.
Get a monitor with VGA input - any laptop should have VGA. It's a rectangular 8(?) pin connector with tapered corners. VGA cable is usually included with monitor. With TV you'll have to buy a VGA cable, costs ~$5 in Canada and US.
17" laptop gobbling battery at astonishing rate? Remove the battery and run laptop through inverter together with detached monitor :)... What is this "astonishing rate", btw? My very old 15" draws max 2A @12V in web browsing mode. 3-4 times less in offline mode, unless I'm watching saved movies. New 17" laptop will probably do better than that.
